delzuk Posted March 17, 2014 Share Posted March 17, 2014 Hello, I have recently installed an Agility. I have found it to be a brilliant system. Having little prior knowledge of Risco systems I have got it all set up using the 2 way keypad. Full/Part set via the keypad works fine. My problem is that I can only get my 2-way 8 button remote to unset and part set. I have two of them both use different pin codes and both of them do the same for some reason they will not full set. Is there something in the programming settings that i'm doing wrong ? I'm hoping that an expert on here has come across this one and can help me. Thanks for looking/reading and helping if you can. ) Richard Quote Link to comment Share on other sites More sharing options...
secureiam Posted May 29, 2014 Share Posted May 29, 2014 (edited) What standard did you use in the panel. The Agility 3 certainly cant set the system with the remote 8 button fob when you employ certain standards. Thats because you are not allowed to use a wireless fob to set on certain standards, without certain other things being done,(my underatsnding is to stop false alarms by accidently setting the system) I am sure I can be corrected by someone on the standards, they way each manufacturer interprets the standards and apply their fiddles can get confusing. risco have decided not to allow setting at all form the 8 button fob when the standard is applied, which is strange as you can have a pin entry on the fob before setting, which would be similar to using the keypad which is wireless the only difference is the keypad is fixed and fob isnt, dont even get me started on the slim keypads which people treat as remotes, they are apparently supposed to be fixed, but its a bit big to put in your pocket. if you default the panel in engineering and not the wireless devices or labels you should be able to use the fob to set and unset Edited May 29, 2014 by secureiam Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted May 29, 2014 Share Posted May 29, 2014 Coming soon - the 16 button fob with LCD display! Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
james.wilson Posted May 29, 2014 Share Posted May 29, 2014 Yeah a smartphone. Re manufacturers restricting options that is because a fair few (Imo) installers don't know the regs Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
norman Posted May 29, 2014 Share Posted May 29, 2014 Yeah a smartphone. Re manufacturers restricting options that is because a fair few (Imo) installers don't know the regsenter Matt. 1 Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
Adi Posted May 29, 2014 Share Posted May 29, 2014 I'd rather not. Quote I really can't be ar**** with it anymore. Link to comment Share on other sites More sharing options...
norman Posted May 29, 2014 Share Posted May 29, 2014 Lol Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
matthew.brough Posted May 29, 2014 Share Posted May 29, 2014 Very funny Quote www.securitywarehouse.co.uk/catalog/ Link to comment Share on other sites More sharing options...
delzuk Posted June 24, 2014 Author Share Posted June 24, 2014 Thank you secureiam , It was a 'standard' issue that had restricted full set. I defaulted the panel and have ignored the standards altogether. It now works perfectly in my opinion. I totally agree that it is strange especially because it does require you to use your pin number to set it on the remote. Thanks again for your time it is really appreciated. Richard Quote Link to comment Share on other sites More sharing options...
