Optima XL6 manual needed
That panel is obsolete now as has been for a while.
I'd reccomend contacting a local approved company and getting it serviced. It will most likely require a new standby battery.
  • 4 weeks later...
  • Replies 76
  • Views 79.9k
Hi I moved into a house with optima xl6 when I turn the power on it keeps going of I do not have the customer code but I know the Engineering code am following the reset but does not seem to doo anything
Please advice
  • 3 years later...
Hello just a quick line to ask where I can get a user manual for optimal xl6 I inherited with recent house move...
On 2/17/2011 at 08:45, Rulland said:
OP wont have access to manuals, so here are the XM guides-one is the 'scanned',the other isn't!.
Optima XM user Guide.pdf
Optima XM user Instructions.pdf
Hi these manuals are the same as the XL panel
  • 1 year later...
On 03/08/2003 at 17:15, Service Engineer said:
I`ve emailed you the manual.
Hi mate, could you mail me pthe manual please if possible? Once code has been typed in should the alarm constantly bleep?
Thanks
This thread is over a decade old.
Manuals are available both in this thread and in the Downloads section.
I suggest you open a new thread in the public forums if you have an issue.
