samauty Posted September 2, 2012 Share Posted September 2, 2012 Good evening everyone, and thanks for accepting my registration ! I hope someone on here can help ! I have recently purchased a new house, and after doing pretty much every job going on it for the past few months, todays job was to install the alarm finally (strange, but I quite like installing alarms - I have put one or two in before) My system is not complex, since the house is not massive, as its my first one. Just so everyone is in the "loop" (sorry for the pun...., here's the specs) Optima Compact panel (Honeywell) 2 PIRs (Honeywell) 2 door contacts External siren (Kinetic AZ-TECH AZ-2000) Ok, so I ve wired up all the zones (both at the sensor end and panel end), wired up the external siren (both at the siren end and panel end), linked out all the unused zones. I ve also linked out the global tamper, keypad tamper and PA, temporally to ensure the panel can be programmed. However, my problem is, the panel is still showing some sort of 24hr zone fault....and is in "locked out" mode. The SOS light is permanently on and after both engineer and user resets the tamper is also flashing. (Btw, this is also with the panel cover back on, and tamper spring depressed) I have also checked continuity between sensors and the external siren on all circuits to ensure the wiring has not been damaged. It appears it hasn't. I am pretty confident when it comes to electrics, and I've done a large variety of tasks, so I would class myself as an experienced DIYer. Any help or suggestions would be massively appreciated. Thanks guys Link to comment Share on other sites More sharing options...
james.wilson Posted September 2, 2012 Share Posted September 2, 2012 Sounds like you either have a sab tamper issue or a duff board securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Oxo Posted September 2, 2012 Share Posted September 2, 2012 Link out every tamper, that includes the SAB. Link out the zones, remove everything apart from the keypad and reboot. As you have done it all and probably have no access to a test meter its back to basics. As in start again from scratch. Link to comment Share on other sites More sharing options...
samauty Posted September 2, 2012 Author Share Posted September 2, 2012 guys thanks for that. When doing a a full re-boot (i.e. factory restore), I am I right in thinking to run a short between the SET terminal on the panel and the LH PA terminal and then power up as per the instructions? I have a test meter if that helps again Link to comment Share on other sites More sharing options...
james.wilson Posted September 2, 2012 Share Posted September 2, 2012 Dont need to factory reset it. Id bet you have a sab tamper issue. Short that out and just power down and up securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted September 2, 2012 Share Posted September 2, 2012 To test the controls wire in only the keypad, link and the other zones and tampers out. Cycle the power and check if it goes to Day mode. Then wire each device in until you find the fault. As mentioned it seems like it's 99% likely to be the bell. Link to comment Share on other sites More sharing options...
Alarm Protection Posted September 2, 2012 Share Posted September 2, 2012 Bell tamper spring closed ok at the bell? ! Link to comment Share on other sites More sharing options...
samauty Posted September 2, 2012 Author Share Posted September 2, 2012 Yeah I did hear the tamper spring click in on the bell, and I've checked all the terminals on the panel and the bell for continuity with the meter.... TBH, I'm thinking the board is duff.... Link to comment Share on other sites More sharing options...
james.wilson Posted September 2, 2012 Share Posted September 2, 2012 an ohm reading wont work on your bell as its a voltage (well a neg) return. Just do me a favour and pull out the wires between T and A (i think thats them) and put a link in there. Or put 0v link to T securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Oxo Posted September 2, 2012 Share Posted September 2, 2012 As I said take it back to how it was at the start. With all the links in when you took it out of the box. Link to comment Share on other sites More sharing options...
