Choosing The Right Product - Texecom
zurrieq
I would recommend at least one door contact on the door that you would normally use to enter the property tbh-you can set a PIR as final or have timed set, but DC is my prefered option.
Will see if I can fit it in as I usually enter from the garage door which opens remotely upwards. Anything you recommend for this?
GSM SWITCH, use your phone to open garage :).
Arfur
Arfur
Interesting. I was replying to an earlier quote where it was recommended to have a door contact in the door where I use most. That happens to be the garage door :)
Interesting though that I can use the garage remote to enable/disable alarm. My only query would be... what happens if someone steals the remote??
