Ade Gen4 - Alarm On Mains Powering Up?
mib150
11 volts at battery?
Best you check the battery output voltage with leads to battery disconnected, you should see ideally 13.65 volts (optimimum for many batteries).
Reasonable DVM's don't round up to the extent you mention, it would be in the hundredths if not thousandths of a volt.
Was the battery you fitted old stock? As They do discharge over a period if time.
Arfur
Reakon charging is ok from that.
:whistle::whistle::oops::oops:
As I was leaving the house, with the battery in my hand, the power light on the keypad went out.
Further investigation lead me to find a loose connection in the mains supply circuit. (this explains the 'deep discharge' :P )
I've sorted this & replaced the battery, so hopefully everything should be OK now??
Sorry for being such an :*******:
many thanks for all your help and advice.
I'll let you know how things are in the next day or so.
cheers again
Marcus
