Master Tp:800
1 hour ago, Davangtrac said:
The screwdriver, 2 batteries and 4 door contacts must be worth a fiver lol.
Nah
It means the shed and it's contents are worth less than a fiver that's all.....
  • Replies 29
  • Views 9.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • #Kneedeepindogshit
  • Nah   It means the shed and it's contents are worth less than a fiver that's all.....
  • Sounds more like you fit them?    Don't be shy, Al will finally be able to Lord it over someone.
Posted Images
With those sensors, it will false alarm constantly on a shed, I guarantee it, and then you will not trust it, and then you will remove it, and then when you are burgled, you won't know...
That said Y I just bought a metal shed from Amazon as a temporary store so we can get on with doing up the annexe. £100 4 x 6 full height, with a metal raised floor frame, not the usual sat-on-the-patio crap.
It's a 'warehouse' clearance product so it'll probably arrive with half the bits missing and need sending back, but until then I thought that was pretty good since they are selling the non-floor model for £250 odd still.
10 hours ago, Davangtrac said:
4 door contacts
Even the door contacts are chinktat contract special. Oddly it's the bells that give these away from the outside, unlike most badge up jobs it seems they really were specially made for this crud. IIRC they supply a 99p grade piezo siren you have to drill to the wall using No.4 screws, they supply the cheapest speaker wire to connect it up via a terminal block, then you put the cover over the top. Yeah as I say pulled a few out, but couldn't reuse a single wire.
Edited by datadiffusion
I have a wireless alarm in at the mo but hate changing the batteries. All I need is 1 door contact and 1 pair, visible wires are no problem so don’t an alarm installer to pull my eyes out. Will keep my eyes looking for another system.
9 hours ago, datadiffusion said:
The door contacts are chinktat contract special. Oddly it's the bells that give these away from the outside, unlike most badge up jobs it seems they really were specially made for this crud. IIRC they supply a 99p grade piezo siren you have to drill to the wall using No.4 screws, they supply the cheapest speaker wire to connect it up via a terminal block, then you put the cover over the top. Yeah as I say pulled a few out, but couldn't reuse a single wire.
No it's called having eyes **** face
Joking aside (you ****) we had one on the back of our house when we bought it, 'Pier Fire Co.' Elmdene Starlight on the front, classy little mix ;)
Obviously I binned the Elmdene and upgraded the Master to a 9448.
3 Zone version
I'm not made of money yeah?
As an alarm man you should be coining it in...
what mickey mouse alarm do you have on your house ?
A Doberman and 2 Rottweilers.
#Kneedeepindogshit
25 minutes ago, MrHappy said:
#Kneedeepindogshit
No fully protected and not full of ****
