- Past hour
Eaton KEY-KPZ01 rapid red flashing
al-yeti replied to AutomationEng's topic in Control Panels (Public)
Althought have you managed to delete the keypad? And need to add it back as a device Does the app allow a virtual keypad? Go through it and see if it sees keypad or not as a wired device -
Maybe then keypad issue - Today
james.wilson replied to AutomationEng's topic in Control Panels (Public)
Agreed sounds like a keypad comms issue. However I'd thought you would get faults reported / logged - Yesterday
Cable fault, I assume it worked on the bench with short cable or check there's no strand shorting out where you connect wires, if spare cores try them instead to keypad -
I programmed an i-onG2SM, in my office. PIRs door contacts, KEY-KPZ01 and network access. Everything worked OK. II then connected it to the actual system, replacing an old Ademco Galaxy. The only thing I didn't connect was the bell box. I also only had the keypad on a short wire, local to the box, while I tested everything else for a few days. This also worked. I have now connected the bell/ strobe and used the old wires to replace the Galaxy keypad with my KEY-KPZ01. For some reason the keypad will only constantly display the Eaton logo and an old date, and the navigation button rapidly flashes red. Pressing any key just causes a beep but does nothing else. The system still works through the Secureconnect app. but I can't do anything with the keypad. Any ideas would be much appreciated. Thanks in advance
Card types and how to get the head around?
Cieska replied to Cieska's topic in General Security & Fire Queries
I was told that I could read the number simply when reading the card. So I guess it is not encrypted. Otherwise, I won't be fighting here. The dashes in Sectors 1 and 2 are because I would think I read this card with mobile NFC? or should I consider something not good here? Well, I'm first time using this mobile app to read the card. -
Using an old PM360 ADT Alarm System
PeterJames replied to Juan Pablo's topic in !!..DIY Installers..!!
Good old Github -
I assumed spam, but looks like good info
james.wilson replied to Juan Pablo's topic in !!..DIY Installers..!!
I need to review links but I'm away from a desktop. -
I'm kind of late to the party, but the final answer to the OP question came in just a few days ago. Between heating and eating I chose... to cancel ADT subscription. At the time of the separation, ADT didn't offer any codes. Fully functional Visonic PowerMaster 360 professionally installed system became abandoned as a result primarily because of the inability to check it via the app remotely. Many thanks to Visonic Powermax and Powermaster Integration for Home Assistant OSS project, it is possible to give Visonic PowerMaster 360 a second lease of life without paying for a rather expensive and totally useless subscription. As a byproduct, the following secret codes, not shared by ADT otherwise, can be extracted from Visonic Power Master 360 and a few other panels on the list: User Codes Master Code Installer Code Master Download Code Installer Download Code Raspberry Pi Zero (£12.59 inc. VAT and shipping) will do the one off code dumping job. It will require a quality micro USB cable, a phone charger with micro USB output and an ability to follow unwritten instructions. NB Raspberry PI Zero doesn't have any network connectivity, so it will be useless for anything else. Although I have some positive experience of running Home Assistant on a sister SBC with 512 MB RAM and Wi-Fi (Zero 2W), Home Assistant hardware requirements are hugely and unreasonably inflated when it comes to RAM. Well, the internet if full of opinions and alternative facts. The panel is self contained. No cloud is required for it to operate. By plugging Home Assistant via Visonic Powermax and Powermaster Integration into PowerLink subsystem via a micro USB connector at the back, the panel is getting an ability for integration with Apple HomeKit, or any other home automation controller either natively when supported, or via MQTT. In addition, the GSM module inside the panel can be configured to send alerts via text messages. Apparently this will require a SIM on a paid contract. As a reminder, the GSM module is 2G/3G, and 3G will not exist in the UK beyond next year (with exception for so much lobbied smart meters, of course) and 2G will be switched off by 2033 at the latest.
sixwheeledbeast replied to Cieska's topic in General Security & Fire Queries
I suppose these are using proprietary Crypto1 format? If so maybe look at the documentation from the people that RE'd it? -
Hi, I know it's my old topic, but I have come back to it. The complication is to understand Card formats and how to read the data. At the moment for example: I have a Mifare Classic 4K card the ACS system by default reads the first 32bit which is the Card Serial Numer (CSN) The system is CEMsys AC2000 I know that I need to read different numbers, which are 8-digit number encoded in Sector-1 Block-2. To read CSN in the card definition setting field of the AC2000 Start position - 1 My question is why is this not start from position - 0 ? As computers read from zero first? As otherwise then all pern doesn't match when counting bits? Or I'm wrong here? Field length - 32 this is where I match my understanding against the CSN as I can read and match the first 32bits (4bytes) or hex value, in the screenshot line 92 of my text editor where I have selected the value. So, if the block length is 128bit (per line), then my interesting data starts at the 6th line which is per block number [05] (text editor line 100) as it starts counting blocks from [00] in the sector [00]. This should mean that it should start read my interesting data from 641bit and the Field length should be 24bits (as 8 digit number fits in 3bytes https://www.rapidtables.com/convert/number/decimal-to-hex.html ) another question here is - if the 8-digit number is encoded in hex or it's just the same number but in numbers only? In other words to say, how the read data is interpreted? Or if the reader reads the CSN number and displays hext then my number also, should be displayed as simple as this? We are talking about reading unencrypted data, as I was told I should read this dara simply when scanning the card. So I have many unknowns in my head, which is why it is totally confusing. I need some guidance or tips. or anything. The -
Texecom Premier Elite - tamper alarm only when door contact is closed
ywu replied to ywu's topic in !!..DIY Installers..!!
I think that's resolved it. I've got an airgap of about an inch between sensor and magnet and it's enough for the alarm to say it's "secure" that the door is "closed". -
There was a gap of around 0.75 cm between the sensor and the magnet before. Maybe i'm putting them too close together and they need that air gap? I've now tried multiple orientations and it still triggers. -
I doubt if your messing with it yourself grade 3 equipment is required. But a grade 3 device is a high security one designed to detect if someone is trying to defeat it with a rouge magnet or one in the wrong location. There will be arrown on the case indicating where they need to line up and it wont have anything like the same tolerance of a grade 2 contact. Id also tidy up your wires there is too much exposed
Is there an issue with it being Grade 3? I have tested it on two sides of the sensor but it's the same issue. Perhaps it matters what the poles of the magnets are used? I haven't tried that yet. -
In preparation for my renovation, I detached the garage door contact sensor and the magnet, which as expected, caused a tamper alarm. The sensor has been put back together and my hope was, I'd bind the two together until the work is done in that area but what I'm finding is the control panel shows a tamper alert when the magnet is brought into proximity with the sensor. No fault is there when they are separated. What might be the issue? Here's what the sensor looks like inside.
Spoons watered down, you want Export.
Do they have JD Weatherspoons?
Nah I think they can get the proper stuff dude .....
Off thier tits on Halal Carlsberg ?
Party time in Iran apparently....
Lol
Who's Online 2 Members, 0 Anonymous, 255 Guests (See full list)
33.2k
Total Topics443.7k
