aissecur Posted October 1, 2014 Share Posted October 1, 2014 Morning Gents, A customer of mine has a Vista (H264) Quantum Dvr (The smaller dvr with no buttons on the front of the unit, everything is mouse controlled) The issue i have is the unit has started rebooting itself 10+ times a day & the customer is not a happy bunny. The PSU is an external 12v one which i have changed (Made sure it was 12V 5amps). I have not changed the Hard drive . I told the customer to remove the LAN connection out of the back of the DVR, this apparently reduced the number of times it rebooted itself... to an odd time. The problem is the customer uses the remote view on his IPhone so need to resolve this. As far as I’m aware the unit has the latest firmware installed but can check & reinstall if required. I have a few thoughts - is the unit being hacked as you can remotely shutdown these units?? I have a Quantum unit myself at home & have noticed lately it reboots itself once a day Has anyone had any similar issues & can advise how i resolve this? Thanks in advance aissecur Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted October 1, 2014 Share Posted October 1, 2014 High P2P on the co-ax's can cause random reboots on some DVR's. If it was being 'hacked' why would it still reboot with the LAN disconnected. You have tried the PSU which would be my first thought, after that maybe HDD issues. Factory default the machine and format the HDD, see if that fixes it? Not played with that model Quantum so I am thinking generic issues here. Quote Link to comment Share on other sites More sharing options...
aissecur Posted October 2, 2014 Author Share Posted October 2, 2014 Hi, Many thanks for your reply… Majority of the camera inputs are via Cat 5 (Baluns), I’m proposing to put Hum Eliminators on the two coax inputs so this would resolve any phasing / earthing issues … Also will probably do a PSCC / Earth loop at the socket outlet that supplies the CCTV equipment just to check there is no iffy readings.. I’m also thinking of reloading the latest firmware again onto the machine & swap out the HDD and format. I just found it suspect that when connected via LAN it rebooted so many times… Quote Link to comment Share on other sites More sharing options...
efficient_systems Posted December 7, 2014 Share Posted December 7, 2014 I've seen this before on a cheap Chinese import DVR, it was caused by a rough DC power rail. Open the case and look for bulging capacitors, these are sometimes caused by the unit being stood on it's side or having other kit sat on top, effectively disabling any airflow vents. Also check for excessive dust build up in the unit, especially if it's installed in an industrial location. If it has bulging caps, replace them and it should be OK. Hope this helps. Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted December 8, 2014 Share Posted December 8, 2014 I've seen this before on a cheap Chinese import DVR, it was caused by a rough DC power rail.That's a blow, comparing a Quantum to cheap Chinese stuff. Open the case and look for bulging capacitors, these are sometimes caused by the unit being stood on it's side or having other kit sat on top, effectively disabling any airflow vents. Also check for excessive dust build up in the unit, especially if it's installed in an industrial location. If it has bulging caps, replace them and it should be OK. While I would agree you could replace blown capacitors yourself, I doubt this is the case here. Also security kit is generally classed as non-user serviceable, plus not many alarm engineers would be capable of a repair like that. The best protocol here would be to send it back or replace. I would be interested if the OP found what the issues was in the end. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted December 8, 2014 Share Posted December 8, 2014 Maybe mains potential on the earth , ie bad earth , pcb failure , host of things Today's pcbs are a hard fix old days you trace each component, unless this Dvr is old style chunky components? Out of curiosity if you temporarily stuck a ups on it does it cure it? Earth to OP? Quote Link to comment Share on other sites More sharing options...
Chopper81 Posted December 8, 2014 Share Posted December 8, 2014 Overheat? All fans working all vents clear from **** build up? Quote Link to comment Share on other sites More sharing options...
efficient_systems Posted December 9, 2014 Share Posted December 9, 2014 That's a blow, comparing a Quantum to cheap Chinese stuff. I didn't compare it, just pointing out that I have seen this fault on a different device. All electronics are comprised of similar components, often expensive devices carry the same components as cheap stuff, it can be useful from a diagnostic POV. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted December 9, 2014 Share Posted December 9, 2014 I didn't compare it, just pointing out that I have seen this fault on a different device. All electronics are comprised of similar components, often expensive devices carry the same components as cheap stuff, it can be useful from a diagnostic POV. You mean cheap resistors? More like cheaper manufacturing process perhaps? Quote Link to comment Share on other sites More sharing options...
21ninja Posted December 9, 2014 Share Posted December 9, 2014 Are there any error messages being shown? I connected my laptop to an spro plus 2 dvr to read the log in detail. As our unit was rebooting randomly and showed loads of errors which pointed towards the hard drive. Quote Link to comment Share on other sites More sharing options...
aissecur Posted December 10, 2014 Author Share Posted December 10, 2014 Hi, thanks for the reply's... The unit is 12vdc & is fed via a 12v 5amp PSU (which I have swapped out) All fan vents clear & no error messages are present on the log.. Unit also clear of dust.. Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted December 10, 2014 Share Posted December 10, 2014 So I take it you haven't found the fault and it is still an issue? Quote Link to comment Share on other sites More sharing options...
aissecur Posted January 9, 2015 Author Share Posted January 9, 2015 Hi, sorry for the late reply... The unit seems to of righted itself after changing the hard drive & fitting a hum eliminator to camera 1. Fingers crossed it keeps on working Thanks for your help / support Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted January 9, 2015 Share Posted January 9, 2015 Im playing with an ssd drive in a dvr at the mo, just for fun mind. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
james.wilson Posted January 10, 2015 Share Posted January 10, 2015 It will die in no time Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
datadiffusion Posted January 10, 2015 Share Posted January 10, 2015 Got it for free to evaluate so will let you know! Only 300GB Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
james.wilson Posted January 10, 2015 Share Posted January 10, 2015 Depending on it id give it 12 - 18 months Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
datadiffusion Posted January 10, 2015 Share Posted January 10, 2015 Interesting, and this is to do with the write not read operations I believe? Might get away with it. The benefits will perhaps outweigh the disadvantages. Application is going to be one of your 4 way analogue DVRs on my van, with recording only with engine on and up to half an hour after key-out. For PSU have a 15v to 12v chinoise regulator off ebay. Front windscreen has a very cheap (but perfectly OK so far) HD all-in-one that I was given also to evaluate, that has it's own lithium batt on board. Had to buy my own memory though! Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted January 11, 2015 Share Posted January 11, 2015 Interesting, and this is to do with the write not read operations I believe? Yes, flash wear from writing or deleting data. Even with wear levelling a SSD in a device that is constantly writing to disk will not last long. About 3000 cycles of the drive before it will become unreliable. So smaller drives would be quicker to die. Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted January 11, 2015 Share Posted January 11, 2015 3000 or 300000? Seems low? Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted January 12, 2015 Share Posted January 12, 2015 3000 or 300000? Seems low? 3000-5000 write/delete cycles. Ideal for data you need to access (read) quickly (OS HDD for example) but not for constant writing (DVR PVR etc) Quote Link to comment Share on other sites More sharing options...
