Help selecting new intruder alarm
@PeterJames ivery helpful, thanks for this. Is it straightforward for me to change the batteries myself?
@al-yeti:
x1 wireless control panel with backup battery
 x1 wireless keypad with prox
x5 fobs
x2 wireless surface door contact
x1 wireless external sounder bell with cover
x1 wireless internal bell
x6 wireless PIR sensor
x1 smartcom
above system will be tested and commissioned.
I am open to having it hardwired. I’m hoping having suspended floors will mean the job is less messy
Edited by Hollanda
  • Replies 55
  • Views 10.1k
  • Part finished new install-     &
  • You can but its not recommended Price for what your getting sounds a little expensive, but there are a few unknowns like parking and any other misc charges.
  • Try local independent installer if possible, your paying *£2640* assume no vat reclaim either  Access to keep cables apart is main issue , depends how much your house you want taken apart
1 hour ago, PeterJames said:
Al-yeti and I both cover South London,
I have the misfortune to be Wandsworth on Tuesday....
I buy std lithium battery's at £1+vat, proper copper 8 core cable is £33+vat a coil
Wiring domestic alarms is work for keen young men... they stopped making them a long time ago
Unless it a building site I'd expect a complete disinterest in offering a wiring alarm or premium over a wired system
Edited by MrHappy
cheers mate much appreciated.
Out of interest why would you recommend Texecom over Pyronix? @al-yeti suggested the same. Is it just that Texecom has more mature tech/app?
For the hardwired option I thought this would be straightforward as I recently had a rewire and thought the engineer could run the 8-core cables along the same path, but looks like they should be at least 150mm apart to avoid interference?
@al-yeti:
x5 fobs
x1 smartcom
Or is apart currently already?
@al-yeti I had a rewire recently and haven’t got round to decorating yet. So some of the suspended floorboards haven’t been nailed down yet which should mean easier access. Open to some additional chasing as long as it’s minimal
They both have more sense & use a completely different product
I use both Texecom & Pyronix,
Do you really want 8 batteries in external sounder?
A keypad which can eat batterys every 6 month?
A "smartcom" which has dumbest way to connect to 2.4ghz wifi ?
 @MrHappy that sounds like a disaster 😂 what would you folks recommend then? I really do want minimal maintenance which is why I’m keen on hardwired system.
My requirement is that it should be a Grade 1 system with the capacity to add response monitoring in case I need it in the future. Trying to also future proof in case insurers ask for minimum Grade 1 system in future.
Edited by Hollanda
The maint money keeps an alarm co. in business
Whats the maint cost £100+vat a year ?
Everything from a co. will be grade 2
You'll only get a Grade 3 wired alarm.
Anything more than an app with need maint + mon
Pyronx app has annual fee, which is why its better than the other 2 I use.
A co. may not wish to provide an app with no maint fee
Hkc
