Pyronix Enforcer V10 Mains Fail Fault
  • Replies 25
  • Views 4.4k
6 hours ago, MrHappy said:
replace the switch mode psu
Doesn't come with the panel? As he said he changed whole panel
I wonder now.....
I wonder now.....
 mmmm if the front was just changed the transformer would not have been replaced
we have changed a few there not the best psu's
I replace the full unit, not just the front, so full new system and PSU
I'd assume the spark may have tested a new spur with your controls attached
I have spare psu's, I did have issues some years ago, they go funny before failing...
The logs show 1 mains fail & loads of tampers & supervision faults ?
Is the sub seeing unreset faults when they put their code in for another tamper or supervision fault?
1 minute ago, PeterJames said:
how many psu's?
1, goes from a spur to a built in step down/PSU to 13-15v, checked voltage on it and gives out correct voltage
