RGodderz Posted May 22, 2025 Share Posted May 22, 2025 I have a stand alone KP500 only attached to an electric strike lock the com NC the key pad is giving the lock power, locking it i have programmed it, with fobs and a code when i swipe the fob or enter the code , the keypad flashes green and accepts it however the power does not drop for the lock the lock will of course open it I take the power off manually taking a cable out Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47262-ryan-godfrey/ Share on other sites More sharing options...
sixwheeledbeast Posted May 22, 2025 Share Posted May 22, 2025 Not used one. Is the strike time really short? Does the strike lock require the same voltage as the KP? Have you tested your findings with a multimeter? Is it just not wired correctly or some other simple mistake? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47262-ryan-godfrey/#findComment-529726 Share on other sites More sharing options...
PeterJames Posted May 22, 2025 Share Posted May 22, 2025 2 minutes ago, sixwheeledbeast said: is the strike time really short? That would be my guess. but as factory standard the timer is usually too long. Have you put the com and n/c in series with the lock and power? I know its a daft question but I have no idea of your ability Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47262-ryan-godfrey/#findComment-529727 Share on other sites More sharing options...
al-yeti Posted May 22, 2025 Share Posted May 22, 2025 59 minutes ago, RGodderz said: I have a stand alone KP500 only attached to an electric strike lock the com NC the key pad is giving the lock power, locking it i have programmed it, with fobs and a code when i swipe the fob or enter the code , the keypad flashes green and accepts it however the power does not drop for the lock the lock will of course open it I take the power off manually taking a cable out Guessing myself Right led flashes? What's left led doing ? Red or green Is it in secure or insecure mode , as I thought one mode requires both fob and code in some sequence Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47262-ryan-godfrey/#findComment-529730 Share on other sites More sharing options...
james.wilson Posted May 22, 2025 Share Posted May 22, 2025 Check the relay is firing with a meter securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47262-ryan-godfrey/#findComment-529734 Share on other sites More sharing options...
