texecom Premier Elite 64-W Takes 1 - 3 minutes befor sounding my alarm
Ive installed my self but it takes ages before it sets of the alarm and thats me walking by all the IR Beams and door contacts
Does anyone know the most likely reason for the lengthy delay before the alarm sounds? maybe 1-3 minutes not timed it yet
Screenshot(202).thumb.png.62defe1be055250c315428dbc0149551.pngScreenshot(201).thumb.png.072a91e077f4f40d378d33a9c7e5cad4.png
Yep I'd also assume the PIR's are in Auto and sleeping.
Door contacts shouldn't do that unless you have programmed them incorrectly. They default to always awake.
