Rsworld.co Posted Saturday at 18:42 Posted Saturday at 18:42 Ive installed my self but it takes ages before it sets of the alarm and thats me walking by all the IR Beams and door contacts Does anyone know the most likely reason for the lengthy delay before the alarm sounds? maybe 1-3 minutes not timed it yet Quote
ian.cant Posted Saturday at 21:06 Posted Saturday at 21:06 Most likely because you are activating the devices just before or during the setting procedure. Wireless devices will go to sleep for a short period after activation to conserve battery life. If you try triggering a device that has not activated recently you should find the system will respond almost immediately. Quote
sixwheeledbeast Posted Sunday at 20:39 Posted Sunday at 20:39 Yep I'd also assume the PIR's are in Auto and sleeping. Door contacts shouldn't do that unless you have programmed them incorrectly. They default to always awake. Quote
