August 30, 20242 yr comment_524737 Keypad is showing the following message: INSTALLER EXIT FLTS Z01 T Front door Any idea how I reset alarm? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46889-ion-16-alarm-fault/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 30, 20242 yr comment_524739 Looks like you have a tamper on that circuit. What has happened? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46889-ion-16-alarm-fault/#findComment-524739 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 31, 20242 yr Author comment_524745 I put the keypad into engineer mode and changed the battery in the front door sensor. I now cannot reset system. The main button on the panel is glowing red, not green. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46889-ion-16-alarm-fault/#findComment-524745 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 31, 20242 yr comment_524747 I'd take the front door contact apart remove battery, make sure you have seated the battery correctly then try to reset again. If the system still thinks the contact is in fault you can't clear down. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46889-ion-16-alarm-fault/#findComment-524747 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 31, 20242 yr comment_524748 2 hours ago, Gary M said: I put the keypad into engineer mode and changed the battery in the front door sensor. I now cannot reset system. The main button on the panel is glowing red, not green. Front door sensor will have a small switch spring to show the contact has closed , probably you didn't close it properly or perhaps broke or dropped the spring or something along those lines Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46889-ion-16-alarm-fault/#findComment-524748 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
