Connecting a Scantronic 9448+ to an from Connecting a Scantronic 9448+ to an Eaton SDR-WEXT-00 external sounder
2 minutes ago, SalopMan said:
If I were to replace it, what would be a good box to get ?
I was going to say is there a comfort light setting, but bell is wired right?
Edited by al-yeti
  • Replies 27
  • Views 11.9k
  • 6 months later...
Scantronic Wired Grade 2 External Sounder | SDR-WEXT-00
Hi, did your ever sort the problem with LEDS flashing all the time on the sounder?  I've followed your problems as I had the same issues.  All working apart from all LEDS flashing
? if you don't want Led's there may be a jumper or dil switch to turn them off ?
  • 1 month later...
18 hours ago, Jon. said:
Hi There, I just read this post I'm in the same situation, did you manage to resolve it? thanks in advance
I don't fully understand the op problem, what is your issue?
