ADEMCO MICROTECH GALAXY 8 PLUS CP171 compatability
49 minutes ago, james.wilson said:
yeah should do
I assumed the OP was making a simple solution complex...
I've never seen the decorative keypad in the flesh, normally the beef with changing stuff is the cost of painter & decorator 🙂
Yeah apparently it was offered as a customer option by the company that "took over" the 3 year old ADT alarm that had been installed by the buile=ders when houses where built in 2000
On 28/02/2024 at 17:05, james.wilson said:
that looks like a 16 plus. Pretty limited and very basic panel. Is obsolete but if its been looked after is useable.
Or put a flex or a 2-20 in its its place. YOu can then reuse your keypad but id update your detection, bell etc
Yeah it says 16+ on the large chip in the middle of the PCB
Hi
Thank you all for your advice.
We've decided to replace the ageing GALAXY 16+ and ditch the idea of trying to keep the existing keypad as I can't find any installers willing to fit any Galaxy products.( only Visionic/Scantronix/Pyronix Euro 46 have been mentioned)
I'll be getting a system professionally installed and hopefully utilising existing cabling (prewired when house was built in Year 2000)
Looking to get all existing motion sensors/Door contacts/Keypad and siren replaced, essentially we need a 4 zone wired system with 3 PIRs 1 door contact,  no monitoring or fancy Apps required.
Would be grateful for your recomendations for a reliable basic alarm to meet those requirements please.
Cheers
Col
I'd be surprised a house with a flush keypad fitted would only need 3 sensors...
If your having a company in it's no good recommending kit, they will use what they support.
If you found somewhere reliable that supports Galaxy then less repair work.
Usual recommendation is 3 quotes, go with the place that makes you feel the most comfortable NOT just the cheapest.
1 hour ago, Colin1208 said:
Hi
Cheers
Col
Hkc
SIA secure it all
https://secureitall.co.uk/
