MrHappy Posted October 22, 2023 Share Posted October 22, 2023 5 minutes ago, Longshanks said: no okay, I had issues with the programming syncing via the cloud & not reflecting the latest change I'd firmware upgrade it with temporary smartcom or pull the pcb & replace the pcb ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
al-yeti Posted October 22, 2023 Share Posted October 22, 2023 35 minutes ago, MrHappy said: okay, I had issues with the programming syncing via the cloud & not reflecting the latest change I'd firmware upgrade it with temporary smartcom or pull the pcb & replace the pcb ? Pull PCB first day of fault was always best maybe Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted October 23, 2023 Share Posted October 23, 2023 Chance of panel being duff is low. I'd have defaulted and isolated things at the time. With only engineers keypad on, if it's still the same then consider panel or firmware. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted October 23, 2023 Share Posted October 23, 2023 3 hours ago, sixwheeledbeast said: Chance of panel being duff is low. I'd have defaulted and isolated things at the time. With only engineers keypad on, if it's still the same then consider panel or firmware. Yes , agreed but with above description and desperate it will give him peace of mind if that at all makes sense , I still do some stupid stuff ....... Quote Link to comment Share on other sites More sharing options...
