Hard Wired Pyronix Deltabell Not Working??
Hi,
I've just hard wired a Pyronix DeltaBell (with backlight) to a Pyronix enforcer panel, but it's not working. It was previously working fine with the same panel at another location. This time, I have not wired the tamper circuit (I removed the switch), as it's up high and the fitting surface is not particularly great. I did a reset on the panel, so the Z33 for the tamper is not active. Endstation ouput/bell output is set to 014 / Siren Any.
I've only fitted 3 wires as follows:
STB on siren to STB on the panel
Bell on the siren to Bell on the panel
12V+ on the siren to +12v on the panel
When the alarm is triggered, the internal siren works fine, the outside siren does not. I don't think the comfort lights are active either?
On the siren, the battery is enabled (J8 jumper is connecting pins 1+2) on INT and the sounder cable is fitted correctly.
Am I being a total n*b, what have I done wrong here?
Thanks
Rob.
4 minutes ago, garnayrob said:
Hi,
Thanks
Rob.
What about the negative ? You still need it
Minimum you need is the
Neg -ve
Pos +12v
- bell trigger
And have the bell set to SCB mode , and make sure the bell tamper is correctly removed , I think you need the switch though for bell to work
The switch would usually have to be closed, it's not sensible disabling it really.
If the sounder isn't suitable for the fixing surface then make it suitable or use a better bellbox.
