May 8, 20233 yr comment_519212 Hi am trying to get a deltabell working with my new risco lightsys plus panel I have set the bell to neg trigger and the strobe to neg trigger and connection to panel OU1 NO=Bell and 0U2 trigger but when the alarm is activated I don't get any sound or Strobe from the deltabell can any 1 help pls here's a pic from the bell wiring Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46038-risco-lightsys-plus-with-pyronix-deltabell/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 8, 20233 yr comment_519213 is the tamper switch unplugged ? Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46038-risco-lightsys-plus-with-pyronix-deltabell/#findComment-519213 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 9, 20233 yr Author comment_519214 Hi yes on the bell the plug is not connected For the cover so the bell does not ring when you open it Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46038-risco-lightsys-plus-with-pyronix-deltabell/#findComment-519214 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 9, 20233 yr Author comment_519215 Is that why the bell does not ring when alarm is activated Kind regards Naeem Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46038-risco-lightsys-plus-with-pyronix-deltabell/#findComment-519215 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 9, 20233 yr comment_519216 You need to have the switch closed for the bell to operate correctly. (or link it with a jumper on the pcb) Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46038-risco-lightsys-plus-with-pyronix-deltabell/#findComment-519216 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 9, 20233 yr Author comment_519217 Hi thanks for getting back to me where do I place the jumper on the bell PCB please as I can't see a option to disable the tamper Kind regards Naeem Just now, Naeem ahmed said: Hi thanks for getting back to me where do I place the jumper on the bell PCB please as I can't see a option to disable the tamper Kind regards Naeem Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46038-risco-lightsys-plus-with-pyronix-deltabell/#findComment-519217 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 9, 20233 yr comment_519222 That NO isn't a relay is it on the panel? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46038-risco-lightsys-plus-with-pyronix-deltabell/#findComment-519222 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 9, 20233 yr Author comment_519228 Hi thanks for getting back yes it's on the panel Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46038-risco-lightsys-plus-with-pyronix-deltabell/#findComment-519228 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 9, 20233 yr comment_519230 1 hour ago, Naeem ahmed said: Hi thanks for getting back yes it's on the panel James is pointing out that your connecting to a relay which unless wired correctly will do nothing Assuming the relay is triggered on alarm the no can stay in the bell trigger , but the c (common needs to connect to negative or minus or -ve ) that way when the alarm triggers it will connect the bell trigger to the negative it requires to ring it Strobe I am not sure , the other outputs are programmable perhaps and you need to look at menus what they can do Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46038-risco-lightsys-plus-with-pyronix-deltabell/#findComment-519230 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 9, 20233 yr comment_519231 Actually opto relays , I couldn't be bothered to see what and how they work in the panel other than that optical relays work similar Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46038-risco-lightsys-plus-with-pyronix-deltabell/#findComment-519231 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
