Amit Posted August 23, 2021 Share Posted August 23, 2021 Scantronic 9651 alarms even when on installer mode, keypad does not show any faults or fault code, on log menu no fault activity shows, all voltages and tampers working ok, is this apanel fault? After reset and on user mode alarms. but again no fault code on keypad, again log does not show any faults. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted August 23, 2021 Share Posted August 23, 2021 27 minutes ago, Amit said: Scantronic 9651 alarms even when on installer mode, Outside box ringing ? or something different ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
Amit Posted August 23, 2021 Author Share Posted August 23, 2021 4 minutes ago, MrHappy said: Outside box ringing ? or something different ? yes bell box rings so does internal bell external bell plus internal bell rings but no display on keypad and no log information Quote Link to comment Share on other sites More sharing options...
MrHappy Posted August 23, 2021 Share Posted August 23, 2021 default & reprogram, if it does it again , replace controls after check the cables.... is this just a system just a single EWD, 1 keypad, 1 speaker & a handfull of pir ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
james.wilson Posted August 23, 2021 Share Posted August 23, 2021 id assume the internal bell is connected to the external and isnt a speaker. Id go with a tamper on one of them but would need to see pics of how its wired Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted August 23, 2021 Share Posted August 23, 2021 1 hour ago, Amit said: is this apanel fault? Could be bell/panel or wire between. depends how it's all wired. If external tamper was linked and bell duff could feedback to internal with no log events, for exmaple. Quote Link to comment Share on other sites More sharing options...
Amit Posted August 23, 2021 Author Share Posted August 23, 2021 3 hours ago, sixwheeledbeast said: Could be bell/panel or wire between. depends how it's all wired. If external tamper was linked and bell duff could feedback to internal with no log events, for exmaple. External bell tamper not Linked. internal bell is a speaker, i have checked the wires to external bell with a meter and all 5 cores tested ok. Yes I do suspect external bell but passes bell and strobe test. Z1 =Front door contact. Z2 = Hallway Pir Z3 = Reception Pir Z4= Dinning Pir Z5 = Kitchen and Garage Pir Z6 = Landing and front room Pir Z7 = Main bedroom and Back room Pir Z8 = Down stairs Upstairs PA. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted August 23, 2021 Share Posted August 23, 2021 cables under carpets ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
al-yeti Posted August 23, 2021 Share Posted August 23, 2021 52 minutes ago, Amit said: External bell tamper not Linked. internal bell is a speaker, i have checked the wires to external bell with a meter and all 5 cores tested ok. Yes I do suspect external bell but passes bell and strobe test. Z1 =Front door contact. Z2 = Hallway Pir Z3 = Reception Pir Z4= Dinning Pir Z5 = Kitchen and Garage Pir Z6 = Landing and front room Pir Z7 = Main bedroom and Back room Pir Z8 = Down stairs Upstairs PA. You wire the pir incorrectly near keypad? 6 hours ago, Amit said: Scantronic 9651 alarms even when on installer mode, keypad does not show any faults or fault code, on log menu no fault activity shows, all voltages and tampers working ok, is this apanel fault? After reset and on user mode alarms. but again no fault code on keypad, again log does not show any faults. What you mean after reset ? Quote Link to comment Share on other sites More sharing options...
Amit Posted August 23, 2021 Author Share Posted August 23, 2021 14 minutes ago, al-yeti said: You wire the pir incorrectly near keypad? What you mean after reset ? user code reset,not full reset. tamper to pir,s wired ass global tamper in series Pir,s are texacom compact pir, checked for tamper loop on each pir back to panel and ok Quote Link to comment Share on other sites More sharing options...
