Alarma and tamper error on Texecom Elite 24
I have upgraded an old Texecom system to an Elite 24 to allow individual zones.  I have inserted the 4.7k and 2.2k resisters into the PIR's connected everything up including an 8 channel expander connected the battery and loaded the factory defaults and got a host of Tamper and Alarm errors. To diagnose the faults I have disconnected the Extender and looped out zones 2 to 8 on the control panel and left zone 1 with a door contacts.  When I power up and load the factory defaults again I get tamper on zone 001 and tempers on 2 to 8 and alarm faults on 1 to 8.  Looping out the unused zones I have used pieces of alarm wire so expected only to see Zone 1 either working or with some sort of error. My plan was to establish a correct zone 1 and then move onto the next Am I missing something here.
Any help would be appreciated  Arthur
  • Replies 20
  • Views 9.2k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
After defaulting the panel, the wiring type will be programmed as double EOL, so any zone that has been looped out with wire, or wired as normaLly closed, which the door contact probably is, will be seen as a tamper. The zone wiring type needs to be programmed as normally closed to conduct the test you have configured.
I don't see a point in doing these tests if your wiring DEOL anyway?
Put all the network and system back and work on each fault.
Reset and see what is left. Repeat.
I have connected to the panel using Wintex and have identified zones 3 to 8 as being 'Not Used' and have connected to door contacts to Zones 1 and 2, these I have identified as Entry/Exit and Normally Closed. Stupidly I expected the Zones to show Green and secure albeit the zones 3 to 8 shown as not in use. As you will see from the attached jpeg the Zones panel showing the two connections and the remaining 'Not Used' and the front Diagnostics panel showing all zones in Red and the first 2 zones and Zone 5 as Active and the the others showing as Tamper.  Zone 5 is a throw back from a previous test that I carried with the first six zones connected - got the same screen.  To me it seems as if the panel retains a memory of previous events.  Operating the two doors did nothing to the diagnostics screen.  The keypads at this stage are not showing the System Faults messages just the standard banner and the date and time.  It would be nice if I could re-set the system and start again.  The system is a wired system using both 6 core and 8 core alarm cables.  The keypads function correctly as does the Bell. When I installed my own system Premier 816 I had no problems at all.
you've put resistors in the circuit & selected normally closed as the zone wiring ?
I'd say above. Could default and start again, then only program out what has no wires. This rules out all the settings you've played with.
I don't believe Zone Status updates in Wintex if set Not Used?
In my initial statement I referred to the resisters that I have installed in the PIR's only, after which I connected PIR's and door contacts and got lots of error messages that I didn't believe.  Because there was so many of them I disconnected all of them and only connected two door contacts which is what I have displayed in the last image, there are no resisters in that scenario. Given that the system now has only two zones connected and the other zones have been declared not used a diagnostics of the system should show Green lights and all saying secure. Any opening of the doors should change the diagnostics to Red and active, the diagnostics screen is live.  I have attached two pictures of my own system diagnostics the first shows that not used (Null) zones show Green and secure and the second is when I wave my hand in front of the PIR in my room and it goes Red and Active.
Putting, in my mind, the simplest connection to the system ie. two door contacts in Zone 1 and 2 I should get a correct response and assuming that they work with only two wires it doesn't matter which way round I connect them, or am I wrong. Is there a way to reset the system to clear all errors and start again from fresh.
I don't believe there is anything wrong with the components, something is just not programmed or wired correctly from what I can gather.
Use the factory default procedure as explained in the manual, we don't provide default information here.
I am assuming this isn't a UK system as the language is not set to UK English? You also mention a 816 which isn't a UK panel.
Or maybe the Elite24 is UK English but you last screenshots are a 816?
The first screenshot with the two display panels together is of my neighbours Elite 24 which should be a UK model (I am interested to know why you think that it is not set to UK English) and the last two images are of my Premier 816 which I installed in 2002 and it is a UK model.  I have tried the Factory Default setting   Reading the manual it states loading the Factory defaults after all of the contacts have been made.  If I follow this procedure with nothing connected will that clear everything and leave the panel as purchased? I realise that loading one item at a time and testing it is a long winded way but I know it is possible to add equipment at a later date, i.e. expanding the system due to an extension of the house as I have done this on my system.  I hope that applying this approach I will eventually find a component that is incorrect in some way.  Do you see any problem with this approach..  Thank you for you assistance.
Edited by sixwheeledbeast
Remove defaulting info
