Alarma and tamper error on Texecom Elite 24
The terms "Interior" and "Bypass" are not UK English terms, 816 was part of "International series" panels.
Factory default as instructions is factory default so everything as factory...
I think your just getting confused with Wintex or something?
You probably only need to make the spare zones Not Used and test regarding wiring type.
  • Replies 20
  • Views 9.2k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Thank you for that you are correct that my Premier 816 does state its international and will not let me change it but my system works fine. My issue is with the Elite 24, if you look into my first image you will see that the zones 3 to 8 are declared as not used but the diagnostics on Wintex is telling be that they have a tamper fault and I don't understand why.
take a picture of the wiring in the panel & take a picture of the device
I'll be more than happy to offer advice*
*which will be in the same paragraph as some proper piss taking
As I said above just ignore it. Not used zones will not matter.
  • 2 weeks later...
So sorry not to have replied sooner but the whole project was put on hold due to a covid infection. I have now resolved all of the connection issues which was due to the previous installation not using common wire protocol.  I now have a problem alarming the system, all zones are allocated to area A only as are the Keypads and the 8 zone extender, I also believe that I have set the system to quick arm, however, when I enter a user code and it asks do you want to arm the system, when I press the yes button nothing happens.  All users have been set to the arm and disarm the system. Any observations would be greatly appreciated. Thank you.
do you get an exit tone & it does not set or an error bleep ?
No I wasn't getting either. Things have moved on I have another problem I keep getting a zone 13 alarm message when I enter the Engineer code and cannot proceed any further.  I have tested the zone 13  resistance and is all looks ok, so I have tried to remove it by [a] removing it from an area [b] Identifying it as Not in Use, [c] Omitting it via the Wintex diagnostics.  But it still shows as being in alarm and I cannot get into any Engineering tasks.  Would a factory default setting help?
latest update. Sorted alarm on Zone 13 and am now back to where I was with entering user password and being asked do I want to arm the system, pressing Yes does nothing.  No sounds from the exit sounds from the keypad it just returns to the normal display (Banner and date and time) On entering the code again it still asks do I want to set the alarm the system
Not sure what you mean by Wards.  They are both assigned to area A.  This is a domestic installation where everything is assigned to Area A, however I can't help feeling that the issue is related the Area programming. Area A Arming mode and the Area Arm Suite are both set to Entry/Exit.
