Alx
  • Replies 20
  • Views 3.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • al-yeti
    al-yeti
    But it doesn't use that method does it? You making this all up? I knew you were a blagger
  • Calm down grandad, you're arguing with yourself again.
  • james.wilson
    james.wilson
    Id was/is clever but basic and doesn't handle any interference.  It not data as such In 100ms the panel would pulse between 2.85v to 6.5v  1 pulse for biscuit 1 10 pulses for biscuit 10
It divides one panel zone into 6 separate latching circuits. I suppose not something you see about much any more.
The map six is wired in series with what look like diodes across each circuit. The diodes are all numbered and when the circuit is open it changes the current flow on that circuit so the panel knows which circuit is open.
A very clever design, bit like how ID systems work nowadays.
6 minutes ago, sixwheeledbeast said:
iD ... nowadays?
HKC still have ID
6 minutes ago, Alexander Gibson said:
Are map6s still in use?
personally never seen one,
however alarms... 30+ yr old controls ain't uncommon
I have a site with one, he has a proper alarm as well, but uses the map 6 to check if doors are open before setting, the leds are active wether its armed or not. I would say its 40 years old rather than 30, late 70's early 80s.
