Steely Dan Posted April 21, 2021 Share Posted April 21, 2021 (edited) Had an alarm system fitted years ago by an electrician friend. Everything was working fine for many years, until about 4 years ago. I got a phone call at work from my partner, saying the alarm was going off, and wouldn't stop. A spark on our job asked me what make it was. He then said to press #### as a default code. I phoned her back, she pressed ####, and it stopped, phew! I then became very ill a few days later, and have spent the last few years in and out of hospital. Anyway, i was told that the alarm was going off at random times of day (just internally). She was doing the #### and it sorted it. The alarm hasn't been getting used for four years. I bought a new battery, and put it in. How do i punch my original code into the alarm, now that #### has been getting used for ages (just to shut the thing up)? I tried original code earlier. Absolutely nothing happened. Do i have to press something to reboot the system? It is an old panel, with the rectangular keypad buttons, rather than round ones. Power is lit red. Day is lit green, but they keypad, which from memory used to light up green, doesnt seem to now. Edited April 21, 2021 by sixwheeledbeast no codes please Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted April 21, 2021 Share Posted April 21, 2021 All of it's memory has been lost if you have been using the default code. This means it will need reprogramming, personally I'd want to replace it if it's had memory issues. I would suggest it wants checking over by an alarm engineer but your other post hints you want to DIY so I would say you need to get a half decent digital multimeter so you can test it. Both the reprogramming and use of a multimeter are skills you may have to pick up if your planning to DIY. Quote Link to comment Share on other sites More sharing options...
Steely Dan Posted April 22, 2021 Author Share Posted April 22, 2021 It seems that the new battery hasn't solved the problem of it going off internally, any old time. Still using ####factory code to turn it off. When i do punch in the number, the internal alarm goes off, but the tamper light stays illuminated, after i have pressed "reset". It remains illuminated for about 5 minutes, the n goes out. if i want to stop it going off, until i get a new panel, is there a relatively easy way of disabling it? TIA Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted April 22, 2021 Share Posted April 22, 2021 Try not resetting it... Quote Link to comment Share on other sites More sharing options...
james.wilson Posted April 22, 2021 Share Posted April 22, 2021 and you definetly dont have a tamper issue? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Imnotshankled Posted April 28, 2021 Share Posted April 28, 2021 On 21/04/2021 at 15:38, Steely Dan said: Had an alarm system fitted years ago by an electrician friend. Everything was working fine for many years, until about 4 years ago. I got a phone call at work from my partner, saying the alarm was going off, and wouldn't stop. A spark on our job asked me what make it was. He then said to press #### as a default code. I phoned her back, she pressed ####, and it stopped, phew! I then became very ill a few days later, and have spent the last few years in and out of hospital. Anyway, i was told that the alarm was going off at random times of day (just internally). She was doing the #### and it sorted it. The alarm hasn't been getting used for four years. I bought a new battery, and put it in. How do i punch my original code into the alarm, now that #### has been getting used for ages (just to shut the thing up)? I tried original code earlier. Absolutely nothing happened. Do i have to press something to reboot the system? It is an old panel, with the rectangular keypad buttons, rather than round ones. Power is lit red. Day is lit green, but they keypad, which from memory used to light up green, doesnt seem to now. It seems that the code was never changed from default i don't recall any accenta keypads using square keys it may be a concept panel To change the code Press prog Enter your old code Press 7 Enter new code Press reset twice Quote Link to comment Share on other sites More sharing options...
PeterJames Posted April 29, 2021 Share Posted April 29, 2021 On 22/04/2021 at 18:52, Steely Dan said: It seems that the new battery hasn't solved the problem of it going off internally, any old time. Still using ####factory code to turn it off. When i do punch in the number, the internal alarm goes off, but the tamper light stays illuminated, after i have pressed "reset". It remains illuminated for about 5 minutes, the n goes out. if i want to stop it going off, until i get a new panel, is there a relatively easy way of disabling it? TIA Panic button pressed somewhere? Quote Link to comment Share on other sites More sharing options...
