How to disable the optima 2 plus intermittently beeps
Stephen MD
Not sure if it's the right place
We moved into our house 2 years ago. It has an old active alarm system which we have never used (lights on main box alight as well as those on the room sensors). We are renovating the house and will be needing to remove the system.
From yesterday it starts to beep Intermittently every 30 seconds.
it's optima 2 plus alarm
I found the engineer code and had looked at the manual after hours' effort resetting it still couldn't silent the beep. It doesn't quite mention such case and how-to in the manual.
Can anyone adivse thanks!
Edited by Stephen MD
  • Stephen MD changed the title to How to disable the optima 2 plus intermittently beeps
1 hour ago, PeterJames said:
Check the batteries in your smoke detectors intruder alarms dont do intermittent beeps
Yes they do I forget which one does the service beep
Someone here made allot of money from there keypads ......
