My system is current showing a system alert Battery Fault Zone 13.
I don't have anything set for Zone 13, I'm only using zones 9-12.
Is there a way of checking which fault this is as I'm presuming it isn't a problem with the main console as this wouldn't be set to a zone?
Much appreciated!
I would expect there would be some type of detection device programmed on 13 but you may not know about it for some reason.
Have you installed this yourself? It wouldn't be an expander or PSU on Texe they have separate fault text.
Register a new account
Sign in
