November 17, 20206 yr Author comment_506416 I guess i could use door entry fob to set and unset system something like this https://www.doorentryonline.co.uk/acatalog/SR2-Proximity-card-key-fob-reader.html Edited November 17, 20206 yr by btssn add info Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44218-fob-reader-advise/page/2/#findComment-506416 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 17, 20206 yr comment_506417 1 hour ago, btssn said: I don't think client wants to spend more than £50 - £80 current simple set reader has failed is reason for upgrade Including labour? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44218-fob-reader-advise/page/2/#findComment-506417 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 17, 20206 yr Author comment_506418 Just now, al-yeti said: Including labour? I shall hope not ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44218-fob-reader-advise/page/2/#findComment-506418 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 17, 20206 yr comment_506419 1 minute ago, btssn said: I shall hope not ? What about a max 4 set in standalone mode maybe you can use it to set u set , the Honeywell uses a set key switch input ? I can't remember really But you would need the prox tags aswell so £50 no good But what Pete said should work , although a stand alone hkc keypad would do it to if your in the trade Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44218-fob-reader-advise/page/2/#findComment-506419 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 17, 20206 yr Author comment_506420 hmm the galaxy max 4 is more expensive, client is bit cheap skate lolz, i will check manual i believe it uses key switch input so the ss2 could be used to set and unset, i do not need fancy lights as will be fitting next to keypad so just simple set and unset. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44218-fob-reader-advise/page/2/#findComment-506420 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 17, 20206 yr Author comment_506421 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44218-fob-reader-advise/page/2/#findComment-506421 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 18, 20206 yr comment_506425 I think you will struggle, the gen 4 prox option was popular, while fobs can be sorted hardware can't. I'd suggest a panel change securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44218-fob-reader-advise/page/2/#findComment-506425 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 18, 20206 yr Author comment_506429 8 hours ago, james.wilson said: I think you will struggle, the gen 4 prox option was popular, while fobs can be sorted hardware can't. I'd suggest a panel change Already suggested however customer does not want to spend that kind of money may just leave them with keypad until they get fed up. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44218-fob-reader-advise/page/2/#findComment-506429 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 18, 20206 yr Author comment_506430 10 hours ago, al-yeti said: But what Pete said should work , although a stand alone hkc keypad would do it to if your in the trade Do you mean this keypad would keypad function ? most likely not however could be wired to use rf to set and unset https://www.hkcsecurity.com/en-GB/products/intrusion-keypads/rf-rkp---rf-remote-keypad-/ Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44218-fob-reader-advise/page/2/#findComment-506430 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 18, 20206 yr Author comment_506431 would the galaxy mk7 keypad work with this panel as they have built in prox fob Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44218-fob-reader-advise/page/2/#findComment-506431 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
