CP038-01-H is it HID only?
Hi,
Honeywell good on making stuff, but their website that they display products really mess. As Galaxy CP038-01 keypad has in detail specifications but CP038-01-H not really. So my question is: if CP038-01-H accepts only HID cards or it does accept regular fobs as CP038-01 does and HID cards.
Thanks.
1 hour ago, Cieska said:
Hi,
Thanks.
Would accept both
Hi,
Thanks.
On a side the galaxy dimension panel wasn't made for the diyer
Lack of information is more about lack of knowledge, training and experience
So other panels you will find same situation where you don't know what it can and can't do
Edited by al-yeti
I spunked £160 up the wall to check a feature worked only to find it been removed...
its the way it goes ?
Hardcore
What was it then? Ion40 ?
yes, removed 3rd party comms  & completely different pcb
4 hours ago, Cieska said:
Also, this is the main reason why it must be as cheap as possible.
why what must be as cheap as possible?
Ha. My mistake that supposed to reply to my other post about Galaxy mainboard. My bad.
