sl compact
My alarms gone off as my electricity was cut I cant remember the process to turn it off I do no my pass number.
On 16/08/2003 at 07:52, Guest ceemgee said:
I wonder whether anyone has a manual for a SL Compact alarm system, which was installed in my house when I moved in?
I am unable to find it on the Net, as I don't know what SL stands for.
Help!
Thanks.
I could do with a manual if anyone has one
Start another topic?
Model make of alarm etc
sl compact
its an sl compact alarm
  • datadiffusion changed the title to SL Compact Alarm Problems
Alarms that activate like this during a power cut are most likely unmaintained and will require servicing by an engineer.
We do not provide engineering manuals, defaulting procedures, codes or disabling information here.
I can only suggest that you try all the user codes you can think of and if the alarm will not silence you will have to contact someone to repair it.
It's recommended you service your system regularly, (even if you don't arm it often) so this type of thing doesn't happen.
Please don't start another topic.
As above we do not give out enongeering manuals and it's likely you'll need an engineer.
Edited by datadiffusion
Al was right, I already split all this out but I was busy at the time so didn't fix the title or post.
I think we should start on you
