jim239 Posted May 10, 2020 Share Posted May 10, 2020 Hi everyone, I have cracked on with installing my CCTV, I have run a few cat 5 cables and tested them successfully using my Haydon tester. Unfortunately after running a length through some conduit I have found that my tester is flashing both pins 1 & 2 simultaneously and then cycling through the other pins correctly at one end, the other end flashes fine. Will I have to replace the whole cable or will my Hikvision turret camera be ok with the 1 & 2 pins, I guess crossed? I am unsure if the camera uses those pins? I have replaced both ends and redone the connection but it has not fixed the problem. Thanks for any help Regards Jim Quote Link to comment Share on other sites More sharing options...
al-yeti Posted May 11, 2020 Share Posted May 11, 2020 8 hours ago, jim239 said: Hi everyone, I have cracked on with installing my CCTV, I have run a few cat 5 cables and tested them successfully using my Haydon tester. Unfortunately after running a length through some conduit I have found that my tester is flashing both pins 1 & 2 simultaneously and then cycling through the other pins correctly at one end, the other end flashes fine. Will I have to replace the whole cable or will my Hikvision turret camera be ok with the 1 & 2 pins, I guess crossed? I am unsure if the camera uses those pins? I have replaced both ends and redone the connection but it has not fixed the problem. Thanks for any help Regards Jim I came across something like this , was usually the connector or the tester itself even though the connections had be redone , I did them myself and it worked fine Take the connectors off and test the pairs with a meter if it's trouble replacing cable that might not need replacing Quote Link to comment Share on other sites More sharing options...
james.wilson Posted May 11, 2020 Share Posted May 11, 2020 if poe it will need all 8 cores in tact Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
PeterJames Posted May 11, 2020 Share Posted May 11, 2020 can you not power that one locally ? Quote Link to comment Share on other sites More sharing options...
jim239 Posted May 11, 2020 Author Share Posted May 11, 2020 I won’t be able to power it locally unfortunately. I have redone the connection at the remote end and I still have 1&2 flashing the same time and now pin 4 is not lighting up at both ends. it may be my connections that are not great so going to try the remote end again and if that fails I will have to replace the cable I guess. it’s annoying as I don’t know where the kink or damage along the cable will be as it’s all in conduit. I also cut it off the drum before testing. I am going to look at the drum to see if I can find the other end to test it before cutting it off. regards Jim Quote Link to comment Share on other sites More sharing options...
MrHappy Posted May 11, 2020 Share Posted May 11, 2020 have you tested your tester with a patch lead which has been purchased as an item made by a factory ? 1 Quote Mr Veritas God Link to comment Share on other sites More sharing options...
al-yeti Posted May 11, 2020 Share Posted May 11, 2020 48 minutes ago, MrHappy said: have you tested your tester with a patch lead which has been purchased as an item made by a factory ? Another IT bod had one of those his cable wouldn't work I told him it's the face plate IPC tester showed him what his unit wouldn't Quote Link to comment Share on other sites More sharing options...
jim239 Posted May 11, 2020 Author Share Posted May 11, 2020 Thanks for the reply's, I checked my tester on a known working patch lead to double check and then redone the connections again for a third time at both ends and must have been third time lucky as it is now testing correctly. I have two cameras up now, one left for today and then the tricky couple at the end I think. regards Jim Quote Link to comment Share on other sites More sharing options...
al-yeti Posted May 11, 2020 Share Posted May 11, 2020 17 minutes ago, jim239 said: Thanks for the reply's, I checked my tester on a known working patch lead to double check and then redone the connections again for a third time at both ends and must have been third time lucky as it is now testing correctly. I have two cameras up now, one left for today and then the tricky couple at the end I think. regards Jim Told you Good job and thanks for updating Quote Link to comment Share on other sites More sharing options...
MrHappy Posted May 11, 2020 Share Posted May 11, 2020 1 hour ago, jim239 said: I have two cameras up now, one left for today and then the tricky couple at the end I think. charging by the hour.... Quote Mr Veritas God Link to comment Share on other sites More sharing options...
