scantronic 9600 exit timer problem
1 hour ago, james.wilson said:
you should only have 1 detector per zone/circuit
Map7 on the zones would do the trick, now where did I park my DeLorean....
Sounds like a nice job to swap out with new controls and a smart PSU, split that detection the best way possible. You'd have a good base to start from then, with no weird 30 year old software glitches or NVM memory loss issues.
  • Replies 25
  • Views 4.2k
  • sixwheeledbeast
    sixwheeledbeast
    Map7 on the zones would do the trick, now where did I park my DeLorean....   Sounds like a nice job to swap out with new controls and a smart PSU, split that detection the best way possible.
  • **edit**   take your pic any commercial control would do   the issue you'll have the amount of current drawn,   if your doing DIY & have not moved an over expanded se
  • sixwheeledbeast
    sixwheeledbeast
    All part of other companies, it's survival of the fittest in this game. Aritech = UTC Castle = Hik Menvier = Eaton
or do i somehow try and find a new old stock 9500! i used to use one a few years ago at a shop i worked at and it was pretty good!
In all seriousness i'll likely wait until it gets more frequent then replace it with some fancy new stuff
Going to be some good fun working out how to split the detection circuits haha
18 minutes ago, picasso said:
indeed, theres an additional power supply next to the control panel
in a weird way i'd rather try and keep this going for as long as i can, it really is a lovely control panel to use and has a very nice menu interface
But as i say if the time is up then it's replacement time
I always liked the 9600 and the 9800, but the modern day equivalent is 100 times better. All panels have quicksets for full and part settings, you can have a smart-phone ap  that not only lets you know when its activated it lets you know when your keyholder has disarmed it, you can also arm disarm it from your phone, and control other wireless output such as your gates.
See the thing is i just want a well equipped high quality panel without the smart integration
I'm far from a wireless fan, but if i have no choice then i suppose i'll have to live with it
Most modern day systems have id circuits, allowing you to have 5 detectors wired in parallel but they all have their own id
you want slapping...
You dont have to have wireless the panels are hybrid so you have hard wired and you can add on wireless stuff as you see the need
I wasnt going to say anything but the 95 was horrid
**edit**
if your doing DIY & have not moved an over expanded set of controls about you'll have an interesting learning curve.
Edited by MrHappy
absolutely i do haha!
What are scantronic doing these days? i've looked on a few places but they only seem to do the 9651 which obviously isn't really suitable
3 minutes ago, MrHappy said:
define smart ?
ingratiation to something really expensive eg control4
or some tat you can buy of a website ?
basically the whole phone integration, i don't really see a need for it for my requirements
i have no issues spending money on the right panel, obviously not going to go into b&q and buy a response wireless kit
