Veritas 8C - reset to default
I have a veritas 8c system in my house that I would like to remove and not replace can anyone give advise on how to do it with out ending up with alarm going off and not being able to stop it or is that a engineer only job if so any engineers in Aylesbury availible
We can't give you exact step by step instructions on how to disable your alarm.
As a guide you would need to remove the external sounder first this will involve a ladder and some ear protection as you will trigger the sirens by doing so.
Then you can remove the inside without disturbing the neighbours too much. You will also need some electrical knowledge on how to make the mains supply circuit safe before and after the main panel is removed.
I would suggest if you are not comfortable working with tools at a height, being surprised by loud sirens or working with mains electrics to consider having an engineer out to decommission it.
Out of interest is there a reason for it's removal?
I also wouldn't be removing alarms I'd want them working!
3 minutes ago, Logan said:
I would reccomend having a complaint engineer default the panel and reprogram it to your needs   it will probably also need a new backup battery full service
A complaint engineer?
Is that someone that makes stuff up and sends it in to That's Life?
I have no complaints
I don’t like the great big ugly control panel on the wall maybe I could just have the system updated
Most people that come here dont like a great big ugly burglar in their house LOL!   Seriously though there are several are many alternatives out there depending on what where the controls can be positioned. The biggest problem you will have is that the cables all terminate at the panel, and so they will need to be re-routed to the new panels position, best to call the company that installed it and ask them for a quote to update it
