used menveir / scantronic i-on
The soffits had been redone on one system so I could not get the lid off...
I have now progessed to butchering with an angle grinder
Edited by MrHappy
  • Replies 130
  • Views 27.4k
  • MrHappy
    MrHappy
    it appears "cooper security" have a new product range ?
  • sixwheeledbeast
    sixwheeledbeast
    You should know by now there's always a silent P in Bath.
  • PeterJames
    PeterJames
    I am guessing that this is an abandoned building, I am surprised that the power is on. Logan I am sure that you already know this but you really should not be on top of a lift messing around in an aba
Thanks sugartits, what about the grinder?
diamond blade,  as it was in the machine
1mm would have cut squarer...
Send it to texecom and ask for a refund    i dare you
, ate pizza
Could you send me some im hungry
Edited by Guest
Professional bell destroyer, cut so the tamper loops closed and you can access the terminals.
its older than you!
cut a hole & pull the piezo's off
Decent size holesaw does a good job too, done that a few times when you can't get the roofer out the bottom of a C Type. Saves pulling all the shattered plastic out the gutters and borders later...
