Hilclare 1011
My parents new home has an old Hilclare 1011 alarm installed. There are no instructions - does anyone know how we can get hold of some ?
Also, is there anything behind the door - which seems to be held in place with a screw ? Is it safe to remove screw and open the door while still connected to mains ?
Until they understand how to work it they would like to turn off the mains to the unit - but can't see how to do this - is the switch in the box perhaps ?
Any help much appreciated please
There isn't much to know.
Key position off = off
Etc etc
When was it last serviced I'm amased it's still working
You need to find out what detection there is on the system, at that age I wouldn't be surprised if it's a detector, a door contact and probably a (disconnected) pressure matt.
Once you know this you can systematically work our what detection is in part set v full set.
There may be a fused spur nearby, alternatively it can be done inside the panel but it hurt's if you get it wrong so personally I recommend you get someone over to check it out or even down-power it for you.
Assuming they have purchased the property, all the books & service info should have been requested by their solicitor
Its an alarm from the 1980's , it predates PDF, the internet, the mobile phone ect...
Buy a new system
7 minutes ago, Logan said:
If it works fine theres no point
Nah, you can't support every product for ever....
11 minutes ago, Logan said:
Did you send the PTZ camera you were talking about?
I sent a cheapo junk one with the H Style box,
the thing I sent you was junk pan & tilt network camera,
I didn't like to look of the app (IIRC)
2 minutes ago, Logan said:
Lol.    Is jsb fire alarm panels any good?
we've done this via PM ?
In a few years you'll be getting wrestled out thinking you're from the HSE.
LOL
