MrHappy Posted March 19, 2020 Share Posted March 19, 2020 Quote Mr Veritas God Link to comment Share on other sites More sharing options...
robbo173 Posted March 19, 2020 Share Posted March 19, 2020 The language isn't the issue fortunately, anybody able to help set this touch centre up or reset it some how? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 19, 2020 Share Posted March 19, 2020 31 minutes ago, robbo173 said: The language isn't the issue fortunately, anybody able to help set this touch centre up or reset it some how? Do you have English version instructions? Quote Link to comment Share on other sites More sharing options...
robbo173 Posted March 19, 2020 Share Posted March 19, 2020 Yes I have the full English instructions, the issue is that it doesn't seem to recognise the panel and won't go through the addressing or language options on power up even after pressing the reset button! Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 19, 2020 Share Posted March 19, 2020 1 hour ago, robbo173 said: Yes I have the full English instructions, the issue is that it doesn't seem to recognise the panel and won't go through the addressing or language options on power up even after pressing the reset button! Can you upload some picture of the unit Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted March 20, 2020 Share Posted March 20, 2020 OP, you will need to place the latest English touch center firmware on a FAT32 formatted SD card, then insert the card into the CP045 and power on. The touch enter will then re-flash its firmware and default. You should have received an SD card and firmware with the new touch center. If you are a Selfmon customer, contact me via the Selfmon email for support. If not, then contact your installer. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 20, 2020 Share Posted March 20, 2020 20 minutes ago, GalaxyGuy said: OP, you will need to place the latest English touch center firmware on a FAT32 formatted SD card, then insert the card into the CP045 and power on. The touch enter will then re-flash its firmware and default. You should have received an SD card and firmware with the new touch center. If you are a Selfmon customer, contact me via the Selfmon email for support. If not, then contact your installer. All available online though Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted March 20, 2020 Share Posted March 20, 2020 Yes, Honeywell now post some firmware releases to: https://www.security.honeywell.com/uk/resources/technical-support/software-upgrades/galaxy-software-download-centre No support if you brick your devices though. Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted March 20, 2020 Share Posted March 20, 2020 Interesting that they have there firmware on a public FTP. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 20, 2020 Share Posted March 20, 2020 12 minutes ago, sixwheeledbeast said: Interesting that they have there firmware on a public FTP. They don't care And still no one has bought them ..... Quote Link to comment Share on other sites More sharing options...
