Alarm design advice for 3 bedroom house
hmmm
Perhaps i am being a bit dumb
I drew a little drawing
Basically even if i put a spacer under the mag contact on the window, and get it
to the same "height" as the wireless sender ...the sender is too far away (if you get me)
i mean it is a upvc window but it has fancy plastic 18mm bead around everywhere, and so there is no
SQUARE finish between the fram and window anywhere
I hope u get what i mean
  • Replies 49
  • Views 8.6k
  • For less than the cost of a mobile phone you are protecting your most valuable asset!
  • thats what i did Al,   but the Yale is a Shiece of Pit! it doesnt have a wired sounder and it doesnt have the range of accessories  and its not for me      I gu
  • james.wilson
    james.wilson
    A bit of cable here and there
alternatively fit an external wired contact to the frame/window and wire that into your transmitter
49 minutes ago, EDinMK said:
hmmm
Screwagnet to curve if your not fussed realistically you won't ever remove the magnet or contact , but may replace it and if you move who cares
what a a testicle ache
i just looked at my windows and these are almost identical
i dont know what they cant make some form of "wedge" to fix them to ..i really dont
something like this could work,as long as the tape was strong enough ...no reason it wouldnt work ?
screwing is an option too
You want to screw them not stick. Alse re wedge etc there are thousands of window profile so it's either additional rf sensors or wired. As above I'd use a flush contact(s) but ob my own windows I only use the shock element
You don't use magnets ???
or no lunatic kids like mine who leave windows open day and night
I don't, but I will put them on when I upgrade the heating to room thermostats. I'm currently only using trv and the alarm to set the heating mode, ie comfort(disarmed) , night (part set) or economy (armed)
I will shut off rads based on window and door contacts
I got mags/shocks on all windows now , althought front is contact only would have been nice if mini contacts were being distributed now
Hope it doesn't have some lunatic battery
Its not using a cr123 but then it is little
new keypad is priority, but the contact will be close, in white brown and grey
  • 2 weeks later...
Well I have deceided to flog on this Yale Kit IA220, thanks to being misadvised several months ago I have ended up with a load of accessories that should work but dont :( they are for Easyfit system ...still 866
but not compatible ...
anyway I am going to flog it all on ebay and get a decent one
I initially looked at Pyronix and Texecom
I am pretty sure the Texecom system would work out cheaper ...perhaps.
what do you guys think
I need a system that
** Comes with Wired Bellbox (the only wired kit i need)
** Comes  Wireless Panic Button
**Comes with a dialer or some way of notification
then the standard kit i need is
5 x Wireless PIR
4 x Wireless Contacts
Any Suggestions for me welcomed
