PodMan Posted September 9, 2019 Share Posted September 9, 2019 I have an issue with a Pyronix enforcer alarm kit. The PIR that came is unable to detect in the rear room as there are bifolds and a kitchen which raises the temp too high. I'm looking for a Dual tech PIR and there are 3 available so which is best and easiest to install for a DIY application. FPKX15DT3 ,FPKX15DTAM3, Pyronix Enforcer KX12DT,. cheers Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted September 9, 2019 Share Posted September 9, 2019 So your wiring it? Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted September 9, 2019 Share Posted September 9, 2019 DT isn't going to solve the issue if it's heat or a door in the way. Quote Link to comment Share on other sites More sharing options...
PodMan Posted September 9, 2019 Author Share Posted September 9, 2019 Hi Its a wireless system. I think its a heat issue only as the glass doors and sun ramp up the hest in the room adding the fact that cooking was going on as well at the time it was very hot in there. worked in the evening when the temp had reduced. no doors or obstacles of any fashion in the way.. Cheers Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted September 9, 2019 Share Posted September 9, 2019 Well all those DT's are wired. I don't use Pyronix but wireless DT's are pretty rare, not all manufacturers have them. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted September 9, 2019 Share Posted September 9, 2019 3 hours ago, PodMan said: I have an issue with a Pyronix enforcer alarm kit. The PIR that came is unable to detect in the rear room as there are bifolds and a kitchen which raises the temp too high. I'm looking for a Dual tech PIR and there are 3 available so which is best and easiest to install for a DIY application. FPKX15DT3 ,FPKX15DTAM3, Pyronix Enforcer KX12DT,. Get rid pir and use perimeter protection in that area perhaps you maybe 3-4 contacts / shocks depending on how many opening you have Quote Link to comment Share on other sites More sharing options...
james.wilson Posted September 9, 2019 Share Posted September 9, 2019 Wireless dt i only know of hkc. It wakes the mw part up when needed I'd assume texe have one tho? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
PodMan Posted September 9, 2019 Author Share Posted September 9, 2019 2 hours ago, sixwheeledbeast said: 10 minutes ago, james.wilson said: Wireless dt i only know of hkc. It wakes the mw part up when needed I'd assume texe have one tho? Well all those DT's are wired. I don't use Pyronix but wireless DT's are pretty rare, not all manufacturers have them. Hi again Bought system from SW last week. KX12DQ-WE is wireless has digital temp compensation when room temp matches body temp and the KX12DT is wireless also and is dual tech so which is best. Quote Link to comment Share on other sites More sharing options...
james.wilson Posted September 9, 2019 Share Posted September 9, 2019 What's the issue detection in a hot area or false alarms. I would always go for perimeter in a conservatory etc Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
PodMan Posted September 10, 2019 Author Share Posted September 10, 2019 It’s not a conservatory it’s a heat issue in a large room that is a kitchen/Dining/sitting room with 6m bifolds floor to ceiling. Last Sunday with sun and cooking in the room through the doors the temp rise caused the device not to be able to detect a us moving. No false alarm just did not detect. Pyronix Tech said dual tech or similar. Cheers Quote Link to comment Share on other sites More sharing options...
