Wireless chimer
Can someone kindly advise me?  I am going to install a photo electric perimeter beam (Optex AX-100TFR) which has an alarm output of only 3.6 volts DC.  All the wireless doorbells chimers I'm coming across use 12 volts.  Is there a 3.6v wireless chimer available anywhere?  Thanks very much for any replies.
  • Replies 26
  • Views 4.7k
  • sixwheeledbeast
    sixwheeledbeast
    Not a beam but Texecom KIT-0079, 12v buzzer in a 12v boxed PSU.   An alarm panel option wouldn't have to be used you enable chime and leave it alone.   If you "have to" use the Opt
X y problem?
They are designed to be connected to a wireless transmitter. Then use the contacts on the receiver to drive your wired sounder unit
Out of curiosity ,it has a relay output
I assume your having it on your drive and using it as an alert or something? So it's cabled back to the house?
If so then you can use any PSU with extra relay and any chime
But what do you mean it only has a 3.6v output?
Maybe this version isn't correct for your application so explain application and then perhaps go for another model?
Although you can get small low voltage buzzers
Yes, this is to be used to protect a driveway - it DOESN'T have wired connections, it is a stand-alone battery unit.  So any alarm output has to be wireless.  On the spec, it says the alarm output is 3.6v http://www.securitywarehouse.co.uk/brochure/AX-100_200TFR.pdf  So I assumed I can't simply use a 12v wireless doorbell chimer.  Am I wrong?  Thanks.
I'm open to suggestions of a different product.  I want to protect a driveway with a perimeter beam, but there's no way of running power out.  So it has to be a perimeter beam that is battery operated.  And obviously I need that to trigger an indoor chimer/sounder wirelessly.  Any suggestions very gratefully received.  Thanks.
Yes but those outputs can't drive anything they are pretty much logic states. You need to add a wireless transmitter for the system it is to be used on to relay to the house
1 hour ago, james.wilson said:
X y problem?
Expensive way for driveway chime
Good unit though, what you thinking instead?
3.6v would be perfect for a Scanny 'Breakglass' IF board ;)
https://www.safetysystems.pro/item/12629-scantronic-breakglass-detector-pcb-only
