esw7scottia
Hi Folks.  we have resently taken over a tea rooms with 4 door sensors and 2 pir.  the control is a EUROSEC CP8L  LCD.
There is a problem with the pir in the back room going off more frequently.
this would seem to be low backup battery or faulty pir.
Can I open up the control and replace the battery and at the same time replace the pir?
I dont know if there is an internal tamper alarm, Do you?
Barry And Debs
Barry And Debs
Barry And Debs
Just try it
Worse case if you value the property you will have alarm fixed by an engineer
there will be an internal tamper
I would imagine you will set the tamper off when you up stuff up if that's what the question is?
Internal alarm can be silenced with the user code.
Merged threads please do not post twice.
the tamper went as should, used reset code, and fine,  have fitted a new battery.
