Honeywell Galaxy Flex 20 Configuration.
1 hour ago, al-yeti said:
Correct , with resistors in place
Is it a door contact with no tamper ?
Good bloke you can then also get an RF card later I believe and have wireless zones , unless you already have that
Already have the RF card, see below!
19 minutes ago, al-yeti said:
Sounds ok
Great.
All seems done but I now have a tamper on the RF PORTAL 105.
I don't have any RF Detectors connected?
  • Replies 44
  • Views 13.2k
Great.
Did you fit the spring in the portal?
In the flex you fit a jumper on the tamper header of the portal. There are a few unused jumpers on the existing headers if you don't have any spare.
Could you elaborate? Im not at the house until tomorrow but will check it out.
Again, you'll have to elaborate a little...
I love galaxy but that had to be the fugliest rkp available.
You mean the panel or the install :lol: Its on a temp wall for now until the room is done
No, I meant the actual design of it, it's hideous and looks like a school electronics project.
Thats the only wire I have connecting the RF to the board
Because it's in main box fit jumper next to the top switch
As Mr galaxy said
