Andyh200 Posted December 9, 2018 Share Posted December 9, 2018 I have a Scantronic 9800 (or +) that has had a battery replacement, the engineer code had to be reset during the process - as the alarm was not under any maintenance. The user and engineer codes are now default. The system now shows c-12 and is no longer able to be set, the system only has four zones - three PIRs and a door sensor. Digging through the internet the c and number seems to indicate a zone violation. Can anybody advise? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42553-scantronic-9800/ Share on other sites More sharing options...
MrHappy Posted December 9, 2018 Share Posted December 9, 2018 call a local small co. however if you want to prat about, either z12 need programming out, or z1 & z2 are open ? I'd assume the full system requires programming correctly ? Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42553-scantronic-9800/#findComment-481026 Share on other sites More sharing options...
Andyh200 Posted December 9, 2018 Author Share Posted December 9, 2018 Many thanks for the prompt response, the suggestion of programming out z12 seems to have done the trick. Would the best plan be to program out the other zones that are not used? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42553-scantronic-9800/#findComment-481027 Share on other sites More sharing options...
sixwheeledbeast Posted December 9, 2018 Share Posted December 9, 2018 Seems odd to have an error on Z12 if you have no expander cards on the system (4 zones) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42553-scantronic-9800/#findComment-481028 Share on other sites More sharing options...
Andyh200 Posted December 9, 2018 Author Share Posted December 9, 2018 I've managed to get the system working now, it didn't make sense to me to being seeing an error on a zone that doesn't exist without an expander. Tested a full/part set and things appear to be working correctly now. Many thanks for the responses and guidance, it it very much appreciated. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42553-scantronic-9800/#findComment-481029 Share on other sites More sharing options...
MrHappy Posted December 9, 2018 Share Posted December 9, 2018 Default it & reprogram it Personally I'd bin it & fit something new Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42553-scantronic-9800/#findComment-481031 Share on other sites More sharing options...
sixwheeledbeast Posted December 9, 2018 Share Posted December 9, 2018 Wouldn't provide me with much confidence. NVM could be on the way out. I am all for maintaining a fully working system but if your getting problems at that age it's time to consider controls replacement. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42553-scantronic-9800/#findComment-481034 Share on other sites More sharing options...
Ranson Posted March 14, 2019 Share Posted March 14, 2019 Bin it 2 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42553-scantronic-9800/#findComment-483357 Share on other sites More sharing options...
