Hello
Hello, I’m new to the site, installed my Agility system about 4 or 5 years ago and just recently got broken into, anti snap locks now fitted!!!
i have just added the gsm module so I can be texted when the alarm goes off but i can’t find where I set which number it should call (my number), it’s all working as I can text the sim and set/unset the alarm but that’s not really why I got it.
I have a feeling it under the follow me menu but when I try going into the menu it displays “Not Available”, anyone got any suggestions before I contact Risco tech help and make myself look a fool?
  • Replies 21
  • Views 6.7k
  • I think you’re using the wrong commands to set and unset your alarm, you should be using S to set and US to unset so if your code is 1234 then you would use 1234 S to set and 1234 US to unset (I don’t
  • Glad it worked, I think its just P for part set, have a look at the list below:     I'll see if i can find a link to the update manual for you
  • There are various versions of the user manual that have slightly different commands, such as A and H for arming and disarming (as you found out). The manual I have uploaded is as close to my original
Thought the GSM module didn't call only text?
It does only text but it needs a number to send the text to, I can’t find where I set this number which would be my mobile number
Managed to enable follow me which had opened up a number of menus but still can’t find where I set the follow me phone number which I assume is the number the agility calls to send the sms to
Got it sorted, it’s in the user Manual rather than the engineer Manual, just in case anyone else has the problem this is how it’s done:
 You send the following text to the sim in your alarm.
code FMPHONE n NEW number
code is the user code for arming alarm.
n is the follow me number, I used 1.
number is the number you want texting.
  • 3 weeks later...
That's great to know - I just installed a GSM module too. Waiting for my giffgaff sim to arrive. What SIM do you use?
Also can you add multiple Follow Mes for the text e.g:
1234 FMPHONE 1 NEW 07123456789 (FOR ME THE GRAND MASTER)
4321 FMPHONE 2 NEW 07912345678 (FOR USER 2 - THE WIFES PIN)
Hi mate, I’m getting the same message - not available.
How did you enable the follow me?
I’m still waiting to install my sim.
Yes you can, I used m2m (machine 2 machine) they ensure you sim will never expire
ok, I think you need to go into engineers menu using * 0132
 Then go into programming #
Then system #
then controls #
the communications #
Fm enable half unlock symbol (y/n)
