Texecom prox tag /fobs info
People for the premier elite keypads can you only use texe tags or are other ones ok to use
We normally use visonic and galaxy systems and got a load of their chicklets and fobs and left a couple on site after installing a texe panel and keypad for customer to programme but their not working
Obviously we are not fully clued up on the texe stuff but do they work a bit different as I know the visonic chicklets and galaxy fobs do work eotb each other and scanny keypad etc...
cheers all
the Texecom reprogrammes the fob i believe so std em fobs won't work
I thought standard fobs work, and only a problem if you have it programmed to more than one system ?
Y the negative lol
It is fact if you use a fob somewhere else and then use it on a texe it will delete what you did before or something like that
And depends on your definition of standard fobs , copy fobs lol pretty standard if you ask me
it is worrying how many people think they are secure
I never understood Prox unset
Why isn't it Prox set , code unset or I probably confused anyway lol
The problem was that customers forgot the code on the way in, it didnt matter if they forgot it on the way out.
Standard fobs wont work with texe, you can prog texe fobs to work with other panels. There are a few manufacturers that have used secure format, and others that have used facility codes so that other fobs dont work with their panels but very few are actually using a format that cannot be read at all
Not sure if you install the q70 but odd how the new Honeywell wafer type won't work with them , but they work with the remote keypads
And yes your new grey ones work very well many lol they seemed to have fast response compared to rest
Haha another negative , what a muppet
I thought it was a compliance thing , it being in certain sections of most programming on many panels, meaning the Prox unset restrict keypad blah blah
