Tenanted flat where outside alarm box flashing. number 8 illuminated on upper set  of numbers on keypad.   Neither owner nor tenant can recall security code.  Any help or advice welcome.
  • Replies 30
  • Views 11.4k
  • https://www.gov.uk/government/publications/smoke-and-carbon-monoxide-alarms-explanatory-booklet-for-landlords/the-smoke-and-carbon-monoxide-alarm-england-regulations-2015-qa-booklet-for-the-private-re
The strobe will continue to flash until the system is reset, to do this you would require the user code, speak to the landlord would be my advice.
Thanks Norman , but as I stated in the original post neither the tenant nor the owner (landlord) know or remember the user code.
Sussed out the security code . External light seems to have stopped flashing however the upper  number 8 on the keypad is flashing. What does this mean?
Upload a photo of the keypad or model number, guessing a 800l or similar.
C and K Securitech  C 023-203  Iss 1 . Looks like this attachment .
what happens when you enter code followed by #
Nothing  happens . The upper number 8 continues to flash after the code # is pressed.
Are you sure you have the correct code?
Try inputting the 4 digit code again, does it begin to set?
