Texecom Premier Elite - Cut Cable :(
Ok so I went home and had a go at soldering.
I think I am making a pigs ear of it as the CCA cable strands are really delicate and flimsy.
Also, bearing in mind, this was done on a kitchen table with plenty of light. Doing this on a ladder high up, might yield even worse results.
(a) Be brutal, how bad is my soldering? Image below shows the 3 steps - twist the wire, make a hook, hook onto corresponding wire, add solder to bond together
(b) If my soldering is judged to be real bad, is using a crimp really not advisable?
Edited by MarkJohnson
  • Replies 31
  • Views 7.3k
  • Due to location and space I would go with solder and any type of wrapping , not gift wrap though
  • A regular soldering iron will be fine, if you are unsure have a practice first on some old spare cable.   Lots of tutorials on YT.
  • sixwheeledbeast
    sixwheeledbeast
    60/40 electronics solder or most stock the lead free equivalent, flux is in the solder core (rosin). Do not use plumbing solder it's not suitable.
Another point I omitted - the cut cable is not long enough to join via soldering. An extra 5mm or so in length is needed at points A and B as there isn't any extra pull available on the cable. As such, it looks like I am going to have to cut a small length of cable (marked X in image below) and use that to join cables A and B.
Is that likely to cause issues with the sensor?
It will do
id neaten it up and use heatshrink
Good morning gents! Well, somebody certainly had a fun Sat evening, I can tell you that much! :o
Here is the end result. The system works fine. It doesn't look particularly tidy and I think the extension piece is a little long, but I prefer it to be lose and dangling (!) so there is no stress on the cables.
1. I stripped back the wiring
2. Slid on some 2mm diameter shrink wrap
3. Twisted each pair of wires together
4. Added a small bit of solder
5. Used a heat gun on the shrinwrap
The only slight issue is that I was a bit overzealous with the gun in terms of temperatures and melted the plastic sheath of one of the wires, which has now exposed the metal in the cable :( so taped that up with a tiny bit of gaffa tape (I didn't have any electrical tape at the time). I have highlighted this with a blue square in the image.
The cupboard will be up against the wall, with a gap between wall / cupboard of about 8 to 10mm so the wiring will sit there quite happily.
Feedback (however critical) is welcome - can't improve ourselves without it! :)
