Galaxy flex panel
  • Replies 44
  • Views 9.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • welcome back OX!
  • You need to start again with the wiring. It's too messy. Solid cores are too brittle too. Spend £15 on alarm cable.   Connect three cores only at the panel. Say: +12v - brown 0v at
Posted Images
@Galaxy Guyu
Guys please I nead help with this antidrill sensor sc100 now the tamper sensor is working correctly once I click the button the state convert from open to closed but the vibration sensor alarm still open and I cannot set my system coz of it  so please guys I will share the connection from both sides panel and sensor and please help.
Regards,
Here is the pics
@al-yeti sorry bro , I thought that @Galaxy Guy who replied to me I didn't notice the name :) , I need your recommendations bro :)
+12v - brown
0v at the zone - blue
The zone input - green.
At the sensor, connect
Brown  to +12v
Blue to 0v.   Now loop a wire from 0v in the sensor and connect it to NC.
Connect a 1k resistor from NC to C
Connect another resistor between C and T1.
Connect the green wire to T2.
I don't know, out of the frying pan, etc...
Based on the fact the top 100 hits for alarm cable on ebay. amazon etc... etc... or the local DIY shed usual DIYers outlet of choice will be CCA :(
Edited by datadiffusion
+12v - brown
Brown  to +12v
Dude what you on about
He's got the role jumpers still in and using resistors , unless I confused , but if not you need to start again
Instructions far to messy
You don't need resistors at panel end if your using the resistors in the detector to start with , then might be T2 and NC at detector end and a zone on panel
Of course I might be confused I just guessing standard Honeywell positions when eol used
@Galaxy Guyy
@al-yeti I know this also and when I connect the external resistors I don put the jumpers , and btw I applied honeywell standard , the two diagrams in their installation guide but it doesn't work for me
24 minutes ago, Moataz said:
@Galaxy Guyy
So show pictures of what you have?
