Part set Enforcer?
Just now, Amps said:
Have you enabled the keypad for area B?
No I don't think so. Do I have to do this even though I'm not using an RKP?
I don't recall seeing this option but I'll have a look when I'm home from work.
  • Replies 38
  • Views 17.8k
  • datadiffusion
    datadiffusion
    I find a lot of people esp. domestics using a slightly more commercial panel, often choose Areas to try and achieve what most of us would just use Part for.
  • datadiffusion
    datadiffusion
    You're fine, we only get just over a million hits a month at TSI
  • Not sure , but do you have to enable zones to part set , so if the attributes are not set then there's nothing to set    From engineering is that some kind of forced set    Just ke
Thought he wants to part set?
Or is part setting done via areas on the enforcer ?
I think this is what I'm doing (or trying to do).
I couldn't actually find the designated 'Part Set' option, and having the PIR's respond differently in different zones was the only way I could think of getting the same effect.
Unless I missed the part set option?
I fixed an enforcer once , he asked me about part set , his part set was like setting full set and panel was upstairs so never got round to finding out why the B key doesn't part set
I still don't get it lol
Lol! As long as I'm not the only one! ;)
An Enforcer part set is Area B.  Go to Assign Keypads/Readers -> Keypad 00 and assign Area B to it.
Hi there,
Thanks for your reply. I went here and it was already assigned to all zones. However, I set it to A and B, but this hasn't worked :-(
Is Area B assigned to the user code?
I think you are presuming that both the A & B keys will be highlighted when you enter your code. This is not always the case.
Enter your code and the A key is highlighted. If you press the B key is that highlighted?
Thanks for the quick reply.
Yes Area B is assigned to the user code.
If I enter the code, A is highlighted only. If I try to select B, A remains highlighted but B still doesn't come on.
