15 minutes ago, Joe Doherty said:
Sent you a PM James, didnt want to put monitoring prices on here as do not have access to the Trade Forum
Thanks
You should apply then. Ill do the vetting over pm if you want to keep it that way
Not a bad little device, I did some testing and evaluation on it for CSL last month.
Signalling works fine, quite a fast device, Although the IPhone app needed a little tweaking but I'm assuming this would be sorted by now.. Got it setup and controlled by iPhone working on remote set/ unset for all Texecom panels, including veritas.  I can see a market for it.
Even if your just using the app side the arc still have to do the hosting and accounts side
This means there is two prices
1 same as the digiair price ish!  but just slightly cheaper - ARC deals with Keyholders
2 hosting only so just to the app - alot cheaper - No actions from ARC at all!
got a demo unit working fine with just 12v 0v and N/O trigger connected
you dont have to use the keyswitch input
so a straight 3 wire connection at basic level
the contact id dial capture is good through the app - up grade for me at home!
set up and program on the Installers app - MiniAir
then customer logs in and set up notifications for them on there app - My Home Alarm
might get time later do a video and add link
  • 4 weeks later...
  • 6 months later...
Register a new account
Sign in
