elite 24 with exodus smokes
4 minutes ago, MrHappy said:
don't sound right?
then I don't think smoke on a intruder alarm are a good idea
it worked a treat for me, however i understand what your saying as when i read it in the installation inst i read it has communication with a call centre, but it does the trick thanks
  • Replies 21
  • Views 3.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • there's less information on the link...   If TSI gets a link to Diy Not, why no TSI link on Diy Not ?
if you tell me how to edit post i will do,
rather than a large display keypad with 16 ohm speaker which does all the tone (set/ unset, chime ect...)
you have a small display keypad with a "speaker" connected to the programmable output ?
29 minutes ago, Mrhappychappy69 said:
sorted............for anyone interested its an area programming issue, area options 20 set unarmed fire comms to area a,b,c etc etc
Your next level
no large display keypad, however prior to me doing what i said earlier, both the internal and external sounders didnt operate under fire condition in unset mode and now they do
4 minutes ago, al-yeti said:
Your next level
44 minutes ago, al-yeti said:
Solved with no forum help...
but always good to have the expert around
okay... however going back to post 1
18 hours ago, Mrhappychappy69 said:
everything working fine apart from the smokes in unset mode, they don't set the speakers in the rkp off when in unset mode yet when set everything works fine, can anyone help please.
so DIY Not have provided the wrong answer to wrong question but your happy with the solution....
DIY Not Right
2 minutes ago, datadiffusion said:
DIY Not Right
but also DIY Not Wrong...
