PIR's in zone 4 not working
1 hour ago, MrHappy said:
The thieves guild used to have burglary as a 2 man job, sensors wired in parallel would detect 2 men in the 2 separate rooms at the same time.
A common misinterpretation of the guidelines. The 2 man rule only applied in the City of London, in any dwelling house over 1200 square feet, or where the amount of silverware expected to be lifted would be greater than one sackful.
  • Replies 22
  • Views 5.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • the thieves guild used to have burglary as a 2 man job, sensors wired in parallel would detect 2 men in the 2 separate rooms at the same time.   I blame thatcher for breaking the unions ever
  • james.wilson
    james.wilson
    so zone 4 used to indicate. When did you last walk test it succesfully Ok id say they have never worked then.
  • james.wilson
    james.wilson
    yes wire it in correctly. and use a latching sensor.
I now have all sensors working.
I acknowledge that it is not advisable (or compliant) to wire more than one device per circuit since you cannot identify which circuit has activated but until I can upgrade the control panel this will suffice.
The following was helpful.
http://www.securitywarehouse.co.uk/forums/topic/46-wiring-2-or-more-sensors-onto-a-single-zone/
